The Web Server of the SMIS Project at Inria
This page is useful only to the project members which have an account or are subscribed to one of the web services.
If you got to this page by error then you should verify that your browser is new enough as to support HTTP/1.1 protocol. For all the project's web servers you should use only browsers that support the HTTP/1.1 protocol. HTTP/1.0 calls are not supported by the web server.
This is the list of all the important internal web services:
NEW !!!
Here is the NEW project's Certificate Autority certificate needed to access without warnings the secured web spaces: SMIS CA pem file or SMIS CA crt file. When you click on one of the links your browser should offer to install it as a trusted certificate. You should install only one of the certificates in function of which one your browser may accept.
